After successfully setting up my smart rollerblinds, I’m now on a quest to find the perfect wall switch to control them. The ideal setup would have three buttons: Up, Stop, and Down. It should be easy to mount on the wall without any in-wall wiring, and ideally, it should work with Zigbee or Z-wave to keep my network clean.
I stumbled upon the OSRAM Smart+ Mini Switch, which seemed promising, but unfortunately, it didn’t fully integrate as expected. This experience left me a bit puzzled, wondering if there’s a better solution out there.
I’ve scoured the market and forums, but most options either lack the three-button functionality, require unsightly in-wall mounting, or don’t support Zigbee/Z-wave. I’d love to avoid adding more W-LAN devices to my network, but I’m open to it if it means finding the right fit.
Has anyone found a reliable, Zigbee/Z-wave compatible 3-button wall switch that works seamlessly with Home Assistant? Any recommendations or experiences would be greatly appreciated! Let’s see if we can crack this together. ![]()
