After spending several weeks researching and experimenting, I finally managed to integrate my Inventer ventilation system with a smart switch solution! The journey wasn’t without its challenges, but the result is absolutely worth it. Here’s how I did it:
Initially, I was stuck trying to find a compatible smart switch that could work seamlessly with my existing setup. The Inventer system uses a dual switch mechanism, and I wanted to preserve that functionality while adding smart capabilities. After some research, I stumbled upon a WLAN-enabled smart switch that supported both local control and remote operation through Home Assistant (HASS).
The installation process was straightforward, but I had to be careful with the wiring to ensure compatibility with the existing transformer and switches. I documented every step meticulously, which helped me troubleshoot minor issues along the way. The best part? The new setup allows me to control the ventilation levels directly from my smartphone or through voice commands, which is incredibly convenient!
I also wanted to share a tip for anyone looking to integrate similar systems: always check the compatibility of your smart devices with your existing infrastructure. In my case, the zigbee protocol turned out to be the perfect choice for seamless integration without additional hubs.
To anyone still exploring their options, don’t hesitate to reach out if you have questions. I’d be happy to share more details about my setup or help troubleshoot issues! ![]()
