I’ve recently embarked on a journey to integrate my smart thermostat with my new boiler system, and I must say, it’s been an enlightening experience!
I installed the Tado V3+ wireless thermostat, and while it’s been mostly smooth sailing, I had a few questions that I thought I’d share with the community in case anyone else is in a similar boat.
First off, I wanted to clarify how the thermostat interacts with the boiler. I set the desired room temperature to 21°C, and it seems to work seamlessly—turning the boiler on when needed and maintaining the temperature beautifully. But I noticed that the boiler’s water temperature was set to 60°C, and I was a bit confused about how that relates to the radiator temperatures. After a bit of research, I realized that the thermostat doesn’t control the boiler’s water temperature directly; it’s more about regulating the flow to achieve the desired room temperature. That makes sense now!
Another thing I wanted to share is how I’ve optimized my setup for energy efficiency. I’ve programmed the thermostat to lower the temperature slightly during the night and when we’re away, which has made a noticeable difference in our energy bills. It’s all about finding that perfect balance between comfort and efficiency!
I’d also love to hear from others who have integrated their smart thermostats with modern boiler systems. Have you encountered any unique challenges or tips that you’d like to share? The community here is fantastic, and I’m sure there’s a wealth of knowledge to tap into!
Thanks for reading, and I look forward to hearing your thoughts! ![]()
