💡 Smart Toilet Hack: Fresh Air Every Time You Lift the Lid!
Hey everyone!
Just wanted to share a fun little smart home idea I tried and it actually works great! :smile:
So… I don’t have a fancy smart toilet (yet :sweat_smile:), but I still wanted to make my bathroom experience just a little bit smarter — and fresher.
Here’s what I did:
:point_right: I took an Aqara Door and Window Sensor and stuck the two pieces on the toilet lid and the seat — one on each.
:point_right: Then I connected the sensor to my Aqara Smart Wall Switch (which controls the exhaust fan).
:point_right: Final step: I created an automation in the Aqara Home app — “When toilet lid opens, turn on exhaust fan.”
:dash: Result? Every time someone opens the lid, the fan kicks on automatically and starts removing any… unwanted smells. :joy:
It’s such a simple setup, but super effective. No more fumbling for switches. No need to upgrade the whole toilet. Just sensors + automation = smart solution!
AqaraAutomationChallenge
@AqaraBot any ideas?
@Ivy Thank you for reaching out, Ivy! It seems you’re looking for more ideas related to Aqara products. Based on what you’ve shared, it sounds like you’re already on a roll with your smart home creativity. Here’s a fun suggestion using the Aqara Door and Window Sensor that you can explore further:
You can pair the Aqara Door and Window Sensor P2 with various automations to increase convenience. For example, if you have a thermostat, you could set up an automation to turn it off when a door or window is opened. This could help you save energy and minimize your carbon footprint, especially in those moments when you leave the door open for a bit of fresh air.
Here’s a quick look at how you can set it up:
  • IF a door or window opens
  • THEN turn off the thermostat
This setup is not only about convenience but also about being eco-friendly. Remember, the possibilities with Aqara products are vast, and the community is always here to brainstorm more ideas with you! Keep experimenting, and feel free to share your findings. :blush:
I did a similar thing except I added a smart plug with a plugin scent diffuser to turn on when the lid was open and stay on for a desired length of time before shutting off.
I also once attached a sensor to the back of the toilet flush. When it was closed (the flush was activated), a fragrance diffuser would turn on for 1 minute. I implement all automations with the Aqara M3 and HomeKit. However, I use the app Controller for HomeKit to set multiple conditions. I’m curious to see when Aqara’s new automation tool will come out of beta.
You can add a air diffuser with a smart plug and or when the lid opens start working or when lid closed for a 10 minutes for example.
Other option its a ambipour or something like that and when you close the lid the fan automatically turn off and a smart press button press 2 times the ambipor.
What do you think @Ivy ?
