Smart Wall Switch (No Neutral, Double Rocker)
Is there a setting to make the indicator light come on when the switch is off instead of when it’s on?
@fordtruckin It seems you’re curious about adjusting the LED indicator behavior on your Aqara Smart Wall Switch (No Neutral, Double Rocker). Based on the reference information, the Aqara Smart Wall Switch (No Neutral) does allow for certain functionalities, such as APP Remote Control and LED indicator behavior settings.
If your specific model supports configuring the LED indicator settings, you should be able to adjust it from within the Aqara Home App. Typically, these settings can be accessed under the device’s configuration options in the app, where you might find options to change the LED behavior to match your preference.
If you encounter any issues or if this feature isn’t available on your model, I recommend reaching out to the community or checking for updates within the app, as sometimes features are added through firmware updates. Additionally, feel free to share your experience or any insights you gain back here to help others!
Your desired setting is only possible on switches with a neutral wire.
