SmartHome Automation Success Story: 'Goodnight' Routine Setup
SmartHome Automation Success Story: ‘Goodnight’ Routine Setup
Hello everyone! I wanted to share my recent journey in setting up a ‘Goodnight’ routine in my home. It’s been a mix of excitement, a bit of confusion, and ultimately, a great learning experience. I hope this post can help others who are starting their automation journey!
The Vision
My goal was to create a seamless ‘Goodnight’ routine that would:
  • Turn off all the lights in the house
  • Turn on the bedroom lights
  • Turn on the TV in the bedroom
  • Turn on the bathroom light
The challenge here was integrating an older TV that doesn’t have smart integration. I’ve heard great things about the Harmony Hub, so I decided to give that a try. But I also wanted to ensure that the entire setup could be controlled through my Amazon Echo and Alexa.
The Setup Process
1. Running the ‘Goodnight’ Schedule
I started by setting up the basic schedule in SmartThings. Turning off the lights seemed straightforward, but the TV integration was a puzzle. Placing the Harmony Hub near the TV and FiOS STB was the first step. I was relieved to find that the Harmony Hub could indeed turn on both the TV and the STB without needing a physical remote. That was a big win!
2. Alexa Integration
Next, I wanted to ensure that Alexa could trigger the SmartThings routine. I reached out to the community and found out that while Alexa can’t directly run routines not created within its app, there are workarounds. By creating a specific routine in SmartThings and linking it through Alexa, I was able to say, “Alexa, run ‘Goodnight routine’” and have everything turn on/off as needed. It’s a bit of a hack, but it works perfectly!
3. Presence Detection
I also wanted the system to know when I’m away. Using presence keyfobs, I set up a routine that activates when no keyfobs are detected. This routine does several things:
  • Turns off all lights
  • Turns off all TVs
  • Turns on the alarm system
  • Locks all doors
It’s been a great way to ensure everything is secure when I’m out. The only thing I’m still tweaking is getting the alarm system fully integrated, but I’m confident I’ll figure it out with some more research.
4. Time-Based Tasks
Another feature I wanted was time-based adjustments. For example, if I return home before 10 PM, I wanted the living room TV and lights to turn on, but if I return after 10 PM, the bedroom lights and TV should activate instead. I found that SmartThings allows for some time-based logic, but it requires a bit of manual setup. I’m still exploring how to make this more seamless, but the progress so far has been encouraging.
Challenges and Solutions
One of the biggest challenges was ensuring that everything worked smoothly without an internet connection. I read that some integrations rely on cloud-to-cloud communication, which would fail if the internet goes down. To mitigate this, I’ve been researching more reliable local integration methods and backup solutions. It’s a work in progress, but it’s good to know there are options out there.
The Takeaway
Setting up a smart home automation system is a journey, not a destination. There are hurdles, but every solution brings a sense of accomplishment. The key is to start small, research thoroughly, and don’t hesitate to reach out to the community for advice. The support I’ve received so far has been incredible, and I’m excited to continue learning and improving my setup.
If anyone has tips or alternative solutions for any of the challenges I’ve mentioned, I’d love to hear them! Let’s keep the conversation going and help each other create the smart homes of our dreams!
Cheers,
