I’m thrilled to share this innovative project that showcases how to integrate smart technology into everyday life. If you’ve ever found yourself frequently checking your mailbox or wished for a smarter way to monitor it, this video is for you!
In this insightful guide, we explore how to transform a regular mailbox into a smart one using the Aqara Vibration Sensor. The video walks through the thought process of choosing the right sensor, overcoming initial challenges with door contacts and light barriers, and ultimately settling on the vibration sensor for its reliability and ease of use.
The setup process is detailed, including how to configure the sensor in Home Assistant, adjust its sensitivity for optimal performance, and integrate it with automation to notify you whenever something is placed in the mailbox. Whether you prefer notifications via app, voice alerts, or even photos from a connected camera, the possibilities are endless!
What are your thoughts on this smart mailbox solution? Have you considered using the Aqara Vibration Sensor for similar projects? Share your experiences or creative ideas for other smart home applications below! We’d love to hear how you’re innovating with Aqara products.
Fantastic idea. I thought of doing this with a contact sensor, but that would have interfered with the opening of my mail box. So I think your approach is the way to go!
I also have a vibration sensor on my letterbox to speak an announcement throughout the house when the post arrives.
I also add AI description of who it as from the doorbell camera!
The idea is great and I tried to use it for myself in Home Assistant. Problem is, I am living in an appartement and the postbox is mounted on a wall in the stairwell and passing people trigger the sensor as well. I think, I need to adjust the sensivity of the sensor, but how to?
this is awesome! I had tried to come up with an idea on how to be alerted to my mail a long time ago and didnt get anywhere. This should work great, love it!
@the_fricklr To adjust the sensitivity of your Aqara Vibration Sensor, you can do so easily through the Aqara Home App. Here’s a quick guide to help you modify the settings:
Open the Aqara Home App on your device.
Navigate to Vibration Sensor in your device list.
Select More Settings.
Choose Sensitivity adjustment.
You will find three levels to choose from: Low, Medium, and High. Select the one that best suits your environment.
Adjusting the sensitivity should help in reducing false triggers, especially in a busy area like a stairwell. Feel free to experiment with different levels to find the optimal setting for your situation. If you have any further questions or experience any issues, don’t hesitate to reach out or share more about your setup. Happy smart home innovating!
@AqaraBot To use the Aqara app, I need to have a hub to add new devices, but I do not have one since all the Aqara products are registered via Conbee/Phoscon in Home Assistant. Is there another way?
@the_fricklr It sounds like you’re using a third-party Zigbee coordinator, such as ConBee, with Home Assistant to manage your Aqara devices. While the Aqara Home App offers direct settings adjustments for sensitivity, there’s still a way to manage this through Home Assistant without the Aqara hub.
You can adjust the sensitivity of your Aqara Vibration Sensor by accessing the Zigbee configuration in Home Assistant. Here are some general steps you might follow:
Access the Zigbee Integration: Open your Home Assistant dashboard and navigate to the Zigbee integration (ZHA or Zigbee2MQTT), depending on your setup.
Locate Your Device: Find the Aqara Vibration Sensor in the list of connected devices.
Modify Configuration: Check if there are options available for adjusting sensitivity. This could be under device settings or configurations specific to the sensor.
Specific options might vary depending on the version and setup of your Home Assistant and Zigbee integration. If you encounter difficulties or the option isn’t available directly, consider reaching out to the Home Assistant or ConBee community forums for additional support, as they might have specific insights or custom solutions for your setup.
Feel free to share your findings or any other smart home projects you’re working on!
@the_fricklr It sounds like you’re keen to adjust the sensitivity of your Aqara Vibration Sensor without using the Aqara Hub, since you’re utilizing a Conbee/Phoscon setup with Home Assistant. While the Aqara Home App typically requires a hub to modify settings like sensitivity, you might be able to achieve similar adjustments directly within Home Assistant.
Here’s how you might proceed:
Check Device Configuration in Home Assistant: Look into the device’s settings within Home Assistant. Sometimes, integrations like Zigbee2MQTT or ZHA offer options to tweak device parameters, though they might not always match the features available in the native app.
Explore Zigbee2MQTT (if applicable): If you’re using Zigbee2MQTT, you might have access to a wider range of configuration options for your devices. It’s worth checking if sensitivity settings can be adjusted there.
Community Collaboration: Since your setup is somewhat custom, engaging with the Home Assistant or Zigbee2MQTT community can be incredibly valuable. Many users share their configurations and solutions to similar challenges, which could provide you with a workaround or script to adjust the sensitivity.
If these options don’t lead to a solution, you might want to consider temporarily using an Aqara Hub just for initial configuration and then returning to your preferred setup. Feel free to continue the discussion with more details about your setup or any other questions you might have. The community is here to help!
Yes from my experience the Aqara sensor is more reliable than the vibration sensor. The vibration sensor doesn’t always pick up the door opening, unless you slam the door really hard
