Hello,
i installed an U200 lite and it works fine so far.
But i have Problems with the NFC stickers.
I have installed them in the Aqara Home App and the Phone identified them during the Installation, so far so good. But after Installation, the Smartphone doesn’t react to the NFC Sticker?!
NFC is on and i tested all Positions, but no Reaction, Aqara App doesn’t open?
Any Idea how to solve it?
Smartphone is Xiaomi 13T pro with Android 15
Hi,
when you try to read the NFC Sticker is your phone locked? It must be unlocked to read it.
Also could the surface make the NFC unreadable if you stick it on a metal plate .
Hope it could solve it.
maybe you also can try another NFC Sticker to check if there’s a problem with the original NFC sticker - but you need to add the new one first in the app
Thanks for reply!
The Phone is unlocked and it is the original Sticker. I tested both delivered Stickers.
I hold it in the hand but the Phone doesn’t identify it, Installation in the App was without Problems, Phone identified them?!
Hmm, you have another mobile or another family member to double check it if it´s a problem by the Xiaomi phone?
It seems that NFC is in a sleeping Mode.
I will test it with a Google Pixel and give Feedback here
Okay, on Google Pixel it works flawless
So Xiaomi ist the Problem
At least we know the reason now!
I’m sure there is someone with a Xiaomi phone and knows how to turn off this NFC sleeping mode
It seems not, google shows no Result for this Problem
Thanks!
Hello again,
i was able to solve the Problem
I had to disable NFC DND in the NFC Settings, now the Tag will work, it opens a push up Message which asks if i want to open the App, after Confirmation, the Task works.
Great … so all fine now?! Hope you are satisfied with the U200 lite -
I bought one for testing as well - just to see the difference between U200 .
BTW the U200 is really awesome as well - I love the fingerprint and Apple homekey
Yes, it’s really fantastic! But actually i can use it only over BT because the hub is missing. I will get the G410 Door Bell/Camera in a few days, so i can use the whole system over WLAN and VPN from the far
Nice , I´m owning a G410 as well! It´s a great product. I also recommend a M3 or the new upcoming M200 hub for more abilities !!
Exists a manual about all the Functionalities of the G410? It seems that there are only Installation Instructions. Learning by doing?
