SmartThings Arrival Sensor Stability Issue Resolved
Hi everyone, I wanted to share my experience with the SmartThings Arrival Sensor V4 after encountering an unusual issue. Earlier this week, I noticed that my sensor was flipping between ‘present’ and ‘not present’ every few seconds. This erratic behavior started after updating to firmware version 2.2.4. I found it quite perplexing, especially since the sensor had been working flawlessly before the update.
To troubleshoot, I checked my event logs and noticed a pattern of rapid state changes, which didn’t make much sense. I reached out to the community for advice, and one user suggested checking the firmware version and ensuring there were no conflicting automations. After a thorough review, I discovered that a recently added automation might have been causing interference.
I decided to roll back to the previous firmware version as a test, and to my relief, the issue resolved itself. The sensor has been stable ever since. I also reached out to SmartThings support, and they mentioned that this might have been a known issue in the 2.2.4 update, which they are actively addressing.
Takeaway: If you’re experiencing unexpected behavior with your sensors after an update, consider checking for known issues or rolling back to a previous firmware version as a temporary solution. Always ensure that automations are not inadvertently causing conflicts.
I hope this helps someone else who might be facing a similar issue. Happy smart home tinkering! :rocket:
