As I’ve been diving deeper into the world of home automation, I’ve found myself navigating a maze of devices and systems to create the perfect setup for my home. My journey began with a mix of Iris and Samsung sensors integrated into a SmartThings hub, which has been a reliable cornerstone of my system. However, as my setup grew, I encountered some challenges that led me to explore additional solutions, specifically the SmartThings Connect devices.
One of the primary issues I faced was inconsistent connectivity with my Zigbee and ZWave sensors. Many of these sensors would lose connection with the SmartThings hub, leading to frustrating downtime. While I implemented a SmartApp to periodically check connectivity, it was more of a band-aid solution than a fix. The lack of reliable repeaters in my setup compounded the problem, especially since my hub is physically connected to my router via Ethernet, limiting its placement flexibility.
Another challenge arose as I expanded my compute devices, particularly with the desire to transition to Linux. The compatibility issues with Linux-compatible WiFi cards made it essential to find a wired solution for my desktops. This led me to consider WiFi extenders with Ethernet jacks, but finding affordable options that also functioned as Zigbee/ZWave repeaters proved difficult.
Enter the SmartThings Connect devices. These devices promised to act as both WiFi extenders and Zigbee/ZWave repeaters, which seemed like the perfect solution to address both my connectivity and wired network needs. However, I had several questions and concerns before making the leap:
Compatibility with SmartThings Hub: I wanted to ensure that the SmartThings Connect devices could coexist with my existing SmartThings hub, allowing me to continue using the rich functionality of the SmartThings app for managing my automation routines and custom apps.
Network Configuration: I needed clarity on whether the SmartThings Connect nodes could extend my existing WiFi network without requiring one to act as a primary hub. Specifically, I was curious about the ability to have one node connected via Ethernet to my router while the others operated wirelessly across different floors.
Zigbee/ZWave Repeater Functionality: I wanted to confirm that the SmartThings Connect devices could effectively act as repeaters for my sensors, ensuring consistent connectivity without the need for additional hardware or complex configurations.
After extensive research and reaching out to the community, I discovered that the SmartThings Connect 3pk could indeed be configured to extend my existing WiFi network while functioning as Zigbee/ZWave repeaters. This setup allowed me to maintain my SmartThings hub as the primary management device, leveraging its advanced features while utilizing the Connect devices to enhance network coverage and device connectivity.
Here’s how I structured my ideal solution:
Primary SmartThings Connect Node: Connected via Ethernet to my Netgear router, this node extends the 5GHz WiFi SSID and serves as a Zigbee/ZWave repeater.
Secondary SmartThings Connect Nodes: Placed on the other two floors of my home, these nodes extend the WiFi network and provide additional Zigbee/ZWave repeater functionality. They also offer Ethernet jacks for my Linux desktops, ensuring a stable wired connection.
Existing SmartThings Hub: Continues to manage all Zigbee/ZWave devices, custom apps, and scenes, while the Connect devices handle network extension and repeater duties.
This setup has significantly improved the reliability of my home automation system, eliminating sensor connectivity issues and providing a robust network infrastructure for my devices. It’s been a rewarding experience to see how integrating different devices can create a seamless and efficient smart home ecosystem.
I’d love to hear from others who have successfully integrated SmartThings Connect devices into their setups. What challenges did you face, and how did you overcome them? Any tips or tricks would be greatly appreciated!
Happy automating!
