Hey everyone! I hope you’re all having a great day. I wanted to share a quick tip that might help someone who’s in a bit of a bind with their SmartThings hub. I recently had an issue where I reset my SmartThings hub, specifically the STH-ETH200 model, and found myself stuck because I couldn’t locate the welcome code that was originally inside the box. It’s a bit of a panic moment, right? Especially when you’re trying to set everything up again.
I reached out to the support team, and they were super helpful. They mentioned that if you’ve lost the welcome code, there’s a way to retrieve it through the SmartThings mobile app. Here’s how it works:
- Open the SmartThings app and log in to your account.
- Go to the settings menu and select your hub.
- There’s an option to generate a new welcome code. It’s pretty straightforward!
Once you’ve got the new code, you can use it to pair your hub just like you did the first time. It’s a relief to know that you don’t have to worry about losing that code anymore. I also heard that some users have started taking photos of their welcome codes just in case, which seems like a smart precaution.
If anyone else is dealing with this issue or has questions about setting up their hub, feel free to ask! I’m happy to help out or share more tips I’ve picked up along the way. Happy smart home tinkering everyone! ![]()
