So Many Issue with the W600
Where do we begin. I assume a fix is on its way for all of these.
Temperature deviation is insane before it opens the valves. About 1.5 to 2C below target temp
Sometimes does not respond to manual temperature increase in the app.
After setting a 2 hour manual mode period it sometimes does not switch back to the smart schedule.
When in the smart schedule it sometimes doesn’t switch to its next smart schedule period. (You have to manually set a temp then cancel it to get it to switch correctly.)
When linked to a T1 temp sensor it does not always show that temp, but will flip back to it’s own board sensor. Yet in the settings it still shows it’s linked.
Creating a device group and controlling them from the group card they do not respond to a manual increase in temp at all.
When linked with a W100 it will again not always show that temperature and or respond to you setting a temp on the W100.
Were these even tested!
Hi, which firmware are you on? Thread or Zigbee? Most of the points you mention should already be on the list of known issues.
The developers are aware and are working on it.
I’m on the 0_1839 Zigbee firmware
There is a beta firmware update available. Your best bet is to contact support and get your account whitelisted for the update.
