I recently encountered a fascinating challenge with my smart home setup that I’d like to share. It revolves around creating a reliable automation for my mudroom lights, which turned out to be a great learning experience.
The Scenario
I wanted my mudroom lights to turn off automatically after 2 minutes of being on. Sounds simple enough, right? However, I noticed that if I turned the lights on and off multiple times during those 2 minutes, the automation would sometimes fail or stack timers, leading to unexpected behavior. This is a common issue in smart home setups, and I wanted to find a robust solution.
The Solution
After some research and experimentation, I decided to implement a conditional check within the automation. The idea was to ensure that the timer only starts if the lights have been on for the full 2 minutes without being turned off in between. Here’s how I structured it:
yaml
- alias: Auto Turn Off Mudroom
trigger:- platform: state
entity_id: light.mudroom
to: ‘on’
condition: - condition: or
conditions:- condition: template
value_template: ‘{{ as_timestamp(now()) - as_timestamp(states.automation.auto_turn_off_mudroom.attributes.last_triggered) | int > 120 }}’ - condition: template
value_template: ‘{% if states.automation.auto_turn_off_mudroom.attributes.last_triggered == none %}true{% endif %}’
action:
- service: homeassistant.turn_off
- platform: state
The Outcome
This logic worked perfectly! It ensures that the lights only turn off after a continuous 2 minutes of being on, without any interference from intermediate on/off cycles. The conditional check effectively prevents timer stacking, which was the main issue I was facing.
Lessons Learned
This experience taught me the importance of understanding how automations handle state changes and timers. It also highlighted the power of using templates and conditions to create more sophisticated and reliable automations. I’m now more confident in tackling similar challenges in the future.
If anyone has tips or alternative approaches to this problem, I’d love to hear them! It’s always great to learn from the community and share knowledge.
Happy automating! ![]()
