Hey everyone, I wanted to share my experience with resolving a recurring issue I faced with my OpenHAB setup. For those who might be encountering similar problems, I hope this post can offer some clarity and solutions.
The Problem:
I noticed that when controlling my Fibaro dimmers via Google Home, the state updates in OpenHAB weren’t reflecting accurately. Specifically, after sending an ItemCommand 'ON', the dimmer would activate but the state in OpenHAB would incorrectly show as 100% instead of the actual dim level. This was quite puzzling and a bit frustrating, especially since manual refreshes were the only workaround at the time.
The Journey to a Solution:
I started by exploring various forums and community discussions, where I came across suggestions about adjusting the autoupdate settings. However, setting autoupdate=false didn’t resolve the issue—it simply froze the state at 0%. This was a dead end, but it did confirm that the problem lay in how the state was being updated post-command.
After some trial and error, I stumbled upon a helpful workaround: creating a rule that automatically sends an ItemCommand 'REFRESH' immediately after receiving an ItemCommand 'ON'. This approach proved to be effective, ensuring that the state was updated correctly without manual intervention.
The Fix:
Here’s a quick breakdown of how I implemented this:
- Identify the Dimmer Item: Locate the item ID for your Fibaro dimmer in the OpenHAB configuration.
- Create a Rule: Use the Rule Machine to trigger a refresh command whenever the dimmer receives an
ONcommand. - Test the Setup: Verify that the state updates correctly after each command.
Outcome:
This solution not only resolved the state update issue but also restored my confidence in the automation setup. It’s a simple yet powerful fix that leverages OpenHAB’s flexibility to address real-world problems.
Final Thoughts:
It’s amazing how a small tweak can make such a big difference. I’m grateful to the OpenHAB community for their invaluable insights and resources. If anyone else is struggling with similar issues, I encourage you to explore rule-based solutions—they might just be the key to unlocking smoother operations in your smart home setup!
Happy automating! ![]()
