I recently encountered an interesting challenge with my Flux LED RGB controller, and I wanted to share my experience and solution with the community. Hopefully, this can help others who might be facing similar issues!
The Issue:
I installed the SUPERNIGHT WiFi Wireless LED Smart Controller to manage my pool lighting. Everything seemed to work perfectly except for one thing—the red and green color channels were swapped. When I selected red in Home Assistant, the test strip turned green, and vice versa. This was quite puzzling!
The Investigation:
I tested this with two different controllers and even tried adjusting the settings on the LED strips. The problem remained consistent—red and green were consistently swapped. I reached out to the manufacturer for support, but the solution wasn’t straightforward.
The Solution:
After some research, I discovered that this issue might be related to how the controller interprets color channels. I found a workaround by manually adjusting the color settings in Home Assistant to compensate for the swap. It’s not an ideal fix, but it works for now!
Lessons Learned:
This experience taught me the importance of thorough testing before fully integrating new devices into a smart home setup. It also highlighted the value of community support—without the insights from others who had faced similar issues, I might still be stuck!
Tips for Others:
If you’re experiencing color channel issues with your Flux LED controller, here’s what I recommend:
- Test with multiple controllers if possible to isolate the problem.
- Check manufacturer forums or support channels for similar issues.
- Consider reaching out to the manufacturer for firmware updates or patches.
I’m still hopeful for a more permanent fix, but for now, my pool lighting is back to full functionality! ![]()
If anyone has additional insights or solutions, I’d love to hear them. Let’s keep the discussion going!
