Hey everyone, I recently faced an interesting challenge with my smart setup and wanted to share my journey and solution in case it helps someone else. ![]()
So, the issue was about getting my smart plug and Bose SoundTouch speaker to work seamlessly in a routine. The goal was to turn both on with a 5-second delay—ensuring the plug powers up first, followed by the speaker after a brief pause. Initially, it felt a bit tricky, but breaking it down made it manageable. ![]()
First, I realized that without any delay, the commands were sent almost simultaneously. This meant the speaker might try to turn on before the plug had a chance to power up, leading to inconsistent results. After some research, I discovered that adding a small delay in the routine could solve this. It’s all about timing! ![]()
I ended up using a simple workaround by inserting a 5-second delay in the routine sequence. This way, the smart plug gets the command to turn on, and after those crucial 5 seconds, the Bose speaker kicks in. It’s been working perfectly ever since! ![]()
This experience taught me the importance of understanding how devices interact and the value of experimenting with timing in routines. It also highlighted how a small tweak can make a big difference in achieving the desired outcome. ![]()
If anyone else has similar synchronization issues or any other smart home quirks, feel free to share your experiences or questions. Let’s keep the discussions flowing and help each other create those seamless smart home moments! ![]()
