Solving System Monitor Data Visibility in InfluxDB
I recently encountered an issue where the System Monitor sensor data wasn’t appearing in my InfluxDB setup. After some troubleshooting, I figured out the solution and thought I’d share my experience in case others run into the same problem.
The Issue:
I had configured the System Monitor sensor to track disk usage and percentage on my Home Assistant instance. The sensor data showed up correctly in the Developer Tools, but nothing was being recorded in InfluxDB. This was frustrating because I rely on InfluxDB for long-term data retention and visualization.
What I Tried:
  1. Checked Configuration: I made sure the System Monitor integration was correctly configured in my configuration.yaml file. The sensor entities were present, so that wasn’t the issue.
  2. Reviewed InfluxDB Setup: I verified that the InfluxDB add-on was running and that the configuration included the necessary retention policies. Everything looked good on that front.
  3. Examined Data Points: I used the InfluxDB query language to check if any new measurements were being created. Unfortunately, the System Monitor data wasn’t showing up at all.
The Solution:
After some research, I realized that the System Monitor sensor data might not be automatically sent to InfluxDB. I needed to explicitly configure it to do so. Here’s what I did:
  1. Added Sensor to InfluxDB Configuration: I updated my InfluxDB add-on configuration to include the System Monitor sensor entities. This involved specifying the entities in the include section of my InfluxDB setup.
  2. Restarted Services: I restarted both the Home Assistant and InfluxDB services to ensure the changes took effect.
  3. Monitored the Data Flow: After a short while, I checked InfluxDB again and was relieved to see the System Monitor data being recorded properly.
Takeaway: This experience taught me the importance of explicitly configuring data sources in InfluxDB, especially when dealing with new integrations. It’s easy to assume that all sensor data is automatically logged, but sometimes you need to take extra steps to ensure everything is captured correctly.
If anyone else is struggling with similar issues, I hope this helps! Let me know if you have any questions or if there’s another way to approach this problem.
