Alright, so after banging my head against the wall for days, I finally figured out why my Aqara Hub kept dropping offline randomly. Thought I’d share in case someone else is in the same boat.
Quick background: I’ve got the M2 hub and a bunch of sensors scattered across the house. Everything was smooth for a while, until I moved the hub behind the TV (dumb move, I know now). Suddenly, sensors weren’t responding, automations were failing, and I was that guy yelling at his lights.
At first I blamed firmware, Wi-Fi, even a ghost — but turns out it was all about placement. I moved the hub away from metal/TVs/routers, raised it higher (top shelf near the ceiling), and bam — signal issues were gone. Even the far-end door sensor got back to life.
Also, pro tip: I ended up getting a Zigbee plug halfway between the hub and my garage door sensor. It acted like a kind of signal repeater. Didn’t even realize plugs could help strengthen the Zigbee mesh.
So yeah… sometimes it’s not your setup, it’s your furniture placement messing with your smart home
Anyone else dealt with this kind of hassle? Curious to hear where you all place your hubs.
