Solving the Mystery of Sensor Data Retention in MQTT
Hey everyone, I’ve been diving into the world of MQTT and Home Assistant lately, and I wanted to share my journey in solving a tricky issue I encountered. If you’re like me and enjoy tinkering with smart home setups, this might resonate with you!
So, here’s the deal: I’ve been using a Sonoff ZigBee Bridge with Tasmota to connect my sensors to Home Assistant. The setup itself is pretty smooth, but I ran into a snag with retaining the last known value from my sensors. Let me walk you through how I tackled this.
The Problem: My sensors were sending data via MQTT, but whenever there was no new data, the sensor values in Home Assistant would reset to 0°C instead of holding onto the last reading. It was a bit frustrating, especially when I wanted accurate, continuous monitoring.
The Journey: I started by looking into the MQTT configuration in Home Assistant. I knew that MQTT sensors could be set up with availability_topic and payload_available to handle online/offline states, but retaining the last value was the missing piece. After some research, I discovered that the state_topic and value_template settings were key here.
The Solution: I realized that I needed to ensure the MQTT messages included all necessary sensor data each time they published. If a particular measurement (like temperature) wasn’t included in the latest message, Home Assistant would default to 0. To prevent this, I adjusted my value_template to check if the temperature was present in the JSON payload. If it wasn’t, I made sure to fallback to the last known state using states('sensor.ZB_Est_Temperature'). This way, the sensor maintains its last value until a new reading comes in.
Here’s a snippet of how I configured it:
yaml
value_template: >
{% if ‘Temperature’ in value_json[‘ZbReceived’][‘0xB585’] %}
{{ value_json[‘ZbReceived’][‘0xB585’][‘Temperature’] }}
{% else %}
{{ states(‘sensor.ZB_Est_Temperature’) }}
{% endif %}
The Outcome: After tweaking the configuration, my sensors now retain their last known values perfectly! It was a bit of a puzzle, but breaking it down step by step helped me understand how MQTT and Home Assistant interact. I’m thrilled to have this working smoothly now.
A Word of Advice: If you’re facing similar issues, don’t hesitate to dig into the MQTT documentation and explore how different settings can influence your sensor behavior. Sometimes, a small tweak can make a world of difference!
I’d love to hear if anyone else has encountered this or has additional tips to share. Let’s keep the community knowledge flowing! :rocket:
