Stop door exits from triggering doorbell event
I have G400 doorbell and U50 lock. Everyone we leave the house it triggers an event. Is there a way for it to know the difference from a person approaching the door?
Maybe by how motion is first detected from the left side of screen instead of right?
Hi, the G400 has hardware limitations, so human face recognition is available only on the paid server and takes place in the cloud. Sometimes this takes longer and is consequently inefficient.
I don’t personally own a G400, but if it has “disable person/face detection” and “enable person/face detection” as a THEN action in automations, then you just need a door sensor and a hub to make it work.
Just create two automation: one disables face and person detection when the door is opened, second one re-enables it when the door is closed (with a delay to allow people to get away from the door).
Example with a door and window sensor and Camera Hub G3 (it may not be possible with the G400, but I figured it would be worth a try):
Aqara’s G400 page shows separate entry into and exit from a configured zone in its automation example. That’s worth checking in Aqara Home before relying on left versus right in the image, although crossing a zone boundary still does not prove that someone is leaving the house. Motion/person detection and identifying a departing resident are different jobs.
In my Home Assistant setup, I combine Aqara door state with indoor presence for privacy and shading. For an HA-based workaround here, I’d first label an event as a possible exit only when indoor presence precedes the door opening, with a short, automatically expiring window. This is a design suggestion, not a tested G400/U50 setup, and depends on the relevant events being exposed. I’d test that classification in a separate log or notification while leaving normal doorbell alerts and recording unchanged, including an arriving guest and someone outside while the door is open. Unknown sensor states should not suppress alerts.
