@sites Hi there! Let’s try to troubleshoot this step by step.
First, regarding connecting the Dimmer Switch H2 EU to Alexa with your E1 Hub: The device supports both Thread and Zigbee protocols, and Zigbee mode requires a hub (like your E1). When adding it to the Aqara Home app for the first time, you should be able to choose the protocol—select Zigbee if you want to use it with the hub instead of Matter .
Since you don’t have the QR code anymore, you can find the setup code or relevant details in the user manual (you can access it here: Dimmer Switch H2 EU User Manual) .
For the Alexa issue: If the device is showing up as “simple security system” via the Aqara skill, it might be a recognition glitch. Try removing the device from the Aqara app, resetting it (double press, then hold for 5 seconds within 3 seconds of the initial press to reset ), and re-adding it to the Aqara Home app using Zigbee mode first. Then, relink the Aqara Alexa skill to see if it correctly identifies the dimmer.
If Alexa still only offers Matter setup, ensure your Aqara Home app is up to date and the hub is properly connected. Since the reference info doesn’t cover Alexa skill-specific recognition issues, this is a general troubleshooting approach—hope it helps!
If you still run into problems, feel free to share more details, and the community might have additional tips.
P.S. If you need further assistance, you can contact the Customer Service Team via the Aqara Home App (Profile>Help&Feedback>Customer Service) for more tailored support.To address your issue with connecting the Aqara Dimmer Switch H2 EU to Alexa, let’s break down the steps based on available information:
1. Protocol Selection: Zigbee vs. Matter
The Dimmer Switch H2 EU supports both Thread and Zigbee protocols. Since you have an E1 Hub, you can use Zigbee mode (which requires a hub), avoiding Matter setup. When adding the device to the Aqara Home app for the first time, you should see an option to select the protocol—choose Zigbee .
2. Resetting the Device (if needed)
If the device is stuck in Matter mode, reset it to re-enter network configuration:
- Double-press the button, then hold for 5 seconds within 3 seconds of the initial press. This resets the device and enables network connection .
3. Adding to Aqara Home App First
Since you no longer have the QR code, use the setup code from the user manual (available here) . Add the device to the Aqara Home app via Zigbee mode, ensuring it connects to your E1 Hub.
4. Alexa Skill Recognition Issue
If the device appears as “simple security system” in Alexa:
- Remove the Aqara Alexa skill, then re-link it.
- Ensure the device is correctly labeled in the Aqara Home app before syncing with Alexa.
Note
The reference information does not explicitly cover Alexa skill recognition errors, so these steps are based on general protocol and setup guidance. If issues persist, consider contacting Aqara Customer Service for further assistance.
Hope this helps—let us know if you need more details!
