Hi everyone, I wanted to share my recent success in setting up a system to monitor the solar energy my home exports back to the grid. This has been a fun project and I thought I’d walk through what I did in case anyone else is looking to do something similar.
The Goal
I wanted to track how much excess solar energy my home sends back to the grid. This not only helps me understand my energy usage better but also allows me to optimize my solar setup over time.
The Setup
I’m using an Octopus Energy smart meter, which provides real-time power consumption and export data. The data is updated every 10 seconds, which is pretty granular. I also have an EcoFlow PowerStream, which helps manage the energy flow from my solar panels.
The Challenge
When my solar panels generate more power than my home needs, the excess is exported back to the grid. The challenge was to accurately measure this export and convert it into a useful metric, like kWh, so I could track it over time.
The Solution
I created a template sensor in OpenHAB that converts the negative power values (which indicate export) into positive values. This way, I can easily visualize the export data. Here’s a quick look at the sensor setup:
sensor: * platform: template sensors: power_export: friendly_name: “Power Export” unit_of_measurement: ‘W’ value_template: >- {% set demand = states(‘sensor.octopus_energy_electricity_XXX_XX_current_demand’) | float %} {% if demand < 0 %} {{ demand * -1 }} {% else %} 0 {% endif %}
Next, I set up a Riemann sum integral sensor to convert the Watt readings into kWh. This involved some trial and error, but I managed to get it working without the values skyrocketing, which was a common issue I saw others facing.
The Results
Now, I have a clear view of how much energy I’m exporting back to the grid. This has been incredibly helpful for understanding my energy habits and identifying areas where I can improve efficiency.
Tips for Others
If you’re looking to set up something similar, here are a few tips:
- Start small and test each part of your setup before moving on to the next.
- Use OpenHAB’s built-in tools to visualize your data. The map and graph cards are particularly useful.
- Don’t hesitate to reach out to the community for help. There are some really knowledgeable people here who are more than willing to assist.
I hope this helps someone out there who’s looking to monitor their solar energy export. Let me know if you have any questions or if you’d like to share your own setup!
Best regards,
