Success Story: Solving Matter Device Adoption with IPv6
I wanted to share my recent success story with Matter device adoption, as it might help others facing similar issues. I recently purchased some TP-Link Tapo smart plugs and was excited to set them up with Home Assistant and Google Home. However, despite following all the setup instructions, I couldn’t get the devices to be discovered or adopted. Frustration set in as I tried every troubleshooting step I could find online.
Then, I stumbled upon a YouTube video by Eric Welander titled ‘BEFORE getting Matter devices’. In the video, he mentioned something that I hadn’t considered before: enabling IPv6 on my network. I had previously disabled IPv6 on my OPNsense firewall, thinking it wasn’t necessary. After watching the video, I realized that Matter devices require an IPv6 address to function properly.
I quickly enabled IPv6 on my network, configuring it across all relevant settings. To my delight, the TP-Link Tapo plugs were instantly discoverable and adopted by both Home Assistant and Google Home! This was a huge relief and a great learning experience.
I wanted to share this solution because I noticed that enabling IPv6 isn’t something that’s widely mentioned in Matter device setup guides or Home Assistant documentation. If you’re struggling with Matter device adoption, I highly recommend checking your network settings to ensure IPv6 is properly configured and enabled.
It’s amazing how a simple network setting can make such a big difference. I’m now confident in setting up more Matter devices knowing that IPv6 is the key to smooth adoption. Hopefully, this tip helps others avoid the frustration I experienced!
