Hey everyone, I wanted to share my recent success with setting up a Gosund smart plug using ESPHome. I’ve been trying to get this working for a while, and I thought I’d document my journey in case it helps someone else.
I started with Tasmota because I heard great things about it, but I ran into a few issues. The MQTT setup was a bit overwhelming for me, and I kept having problems with the firmware flashing. It was frustrating because I couldn’t get past the initial setup. I tried using TuyaConvert, but it kept bricking the plug. I was really stuck and wasn’t sure if I should continue or try something else.
Then I came across ESPHome, and it seemed like a good alternative. I read through the documentation and decided to give it a shot. The process was a bit daunting at first, but I managed to compile the binary and flash it onto the plug. I was so relieved when it worked on the first try!
Here’s the configuration I used. It’s based on some examples I found online, but I had to tweak it to fit my setup:
yaml
esphome:
comment: Gosund UP111 with power monitoring
platform: ESP8266
board: esp01_1m
wifi:
ssid: “MyWiFiNetwork”
password: “MySecurePassword”
api:
reboot_timeout: 0s
password: “esphome”
sensor:
- platform: hlw8012
sel_pin: GPIO12
cf_pin: GPIO4
cf1_pin: GPIO5
current_resistor: 0.00221
voltage_divider: 955
name: “Washing Machine Current”
unit_of_measurement: “A” - platform: hlw8012
sel_pin: GPIO12
cf_pin: GPIO4
cf1_pin: GPIO5
name: “Washing Machine Voltage”
unit_of_measurement: “V” - platform: hlw8012
sel_pin: GPIO12
cf_pin: GPIO4
cf1_pin: GPIO5
name: “Washing Machine Power”
unit_of_measurement: “W”
binary_sensor:
- platform: gpio
pin: GPIO3
name: “Washing Machine Button”
internal: true
on_click:- switch.toggle: washing_machine_relay
switch:
- platform: gpio
pin: GPIO14
name: “Washing Machine Relay”
restore_mode: ALWAYS_ON
led:
- platform: gpio
pin: GPIO1
inverted: true
name: “Washing Machine LED”
This setup gives me real-time monitoring of the washing machine’s power usage, which is super helpful. I can track how much energy it uses during different cycles and even set up automations based on the power consumption.
I also added a physical button on the plug, which toggles the relay. It’s a nice touch because I can manually override the automation if needed. Plus, the LED indicator shows the current state, so I don’t have to guess whether it’s on or off.
One thing I’m still figuring out is how to log the power usage over time. I know Home Assistant has some built-in tools for this, but I’m not entirely sure how to set it up. If anyone has experience with this, I’d love to hear your tips!
Overall, I’m really happy with how this turned out. ESPHome was the right choice for me, and I’m excited to explore more possibilities with it. If you’re struggling with Tasmota or MQTT, I highly recommend giving ESPHome a try. It’s been a game-changer for my setup.
Looking forward to hearing about your experiences too!
