Hey everyone, I wanted to share my recent success with setting up an automation in my smart home setup. It’s been a bit of a learning curve, but I’m thrilled with how it turned out and thought I’d document the process in case it helps anyone else out there.
The Goal:
I have several sensors spread throughout my home, and I’ve been wanting a way to monitor their battery levels without manually checking each one. The idea was to create a single automation that could trigger alerts whenever any of my sensors reported low battery levels. This would not only save me time but also ensure that I don’t end up with unexpected sensor failures in the middle of the night.
The Challenge:
At first glance, this seemed straightforward. I knew I needed to use a template to pull the sensor’s name into the notification message. I found a template online that looked promising:
“message”: “Battery is Low in one of the sensors: {{ trigger.to_state.attributes.friendly_name }}”
I set this up in my automation, but no matter how I tweaked it, I kept running into an error: homeassistant.exceptions.TemplateError: UndefinedError: 'trigger' is undefined. This was perplexing because the automation was definitely being triggered by the sensor’s state change. Why wasn’t ‘trigger’ recognized?
The Solution:
After spending hours digging through forums and documentation, I stumbled upon a crucial piece of information. The issue was with how the trigger was being referenced in the template. It turns out that in certain configurations, especially when dealing with MQTT-connected sensors, the trigger context isn’t always available in the same way. Instead of using {{ trigger.to_state.attributes.friendly_name }}, I needed to access the sensor’s name through its entity ID. Here’s what worked:
“message”: “Battery is Low in: {{ states.sensor.my_sensor.attributes.friendly_name }}”
By referencing the sensor’s state directly, I bypassed the undefined trigger issue and got the notifications working perfectly.
The Outcome:
Now, whenever any of my sensors detect low battery levels, I receive a clear notification with the specific sensor’s name. This has been a huge help in maintaining my smart home setup without constant manual checks. It’s also given me more confidence in tackling more complex automations in the future.
A Few Tips I Picked Up Along the Way:
- Test Early and Often: Even small changes can have big impacts. Testing each part of your automation as you build it can save you a lot of frustration down the line.
- Check Documentation and Forums: Sometimes the solution is right there in the docs, but it’s easy to overlook when you’re deep into troubleshooting.
- Don’t Be Afraid to Experiment: Smart home setups are all about trial and error. Every failed attempt is just a step closer to the solution.
I hope this little journey helps someone else out there. If you have any questions or tips of your own, I’d love to hear them! Happy automating! ![]()
