Successful Integration of Ceiling Fan with Aeon Minimote
I’m thrilled to share my recent success in integrating my ceiling fan with the Aeon Minimote! This project has been a fantastic way to enhance my smart home setup, and I couldn’t be happier with the results.
Initially, I was a bit unsure about how to control the fan speed using the Minimote. After some research, I discovered that using CoRE to create a piston was the perfect solution. By assigning specific button presses to different fan speeds, I was able to streamline the process and make it user-friendly.
One of the challenges I faced was ensuring the buttons were mapped correctly. However, with some trial and error, I found the right configuration. I also explored alternative methods, like smart apps, but CoRE proved to be the most reliable and straightforward option for me.
Here are a few tips I learned along the way:
  • Plan Ahead: Map out which buttons you want to assign to which functions before diving into the setup.
  • Test Regularly: After each configuration change, test the buttons to ensure they’re working as intended.
  • Stay Patient: Integration can take time, but the end result is well worth the effort.
This project has not only made my home more comfortable but also more efficient. I’m excited to tackle more smart home projects in the future! :rocket:
