Hi everyone, I wanted to share my recent success in integrating a Deconz color temperature light with Google Assistant. I’ve been on an OpenHAB journey and decided to tackle this project, thinking it would be straightforward. Little did I know, it would be a bit of a puzzle to solve!
Initially, I set up my light using the default channel for brightness and tried controlling the color temperature through Google Assistant. Everything worked smoothly for brightness adjustments, but when it came to setting the color temperature, I encountered some unexpected behavior. The light didn’t respond as I hoped, and I noticed some errors in the logs. I experimented with different channel configurations, but each attempt brought its own set of challenges.
After some research and trial and error, I discovered that specifying the correct channel for color temperature was crucial. I adjusted my item definition to target the color_temperature channel instead of the default brightness channel. This small change made a world of difference! Now, when I say, ‘OK Google, set pippo to 6000°K,’ the light responds perfectly, adjusting its color temperature without any issues.
This experience taught me the importance of carefully configuring each channel and double-checking the documentation. It also highlighted how rewarding it can be to solve these kinds of technical challenges. I’m thrilled that my light now works seamlessly with Google Assistant, providing the perfect ambiance for my space.
If anyone else is working on similar integrations, I highly recommend paying close attention to channel configurations and testing each setting thoroughly. Happy tinkering everyone! ![]()
