I recently undertook a project to integrate a Shelly 2.5 device with my roller shutter system, and I wanted to share my experience and some troubleshooting tips with the community. While the setup was relatively straightforward, I encountered a few hiccups along the way that I believe others might find helpful to navigate.
Setup and Initial Configuration
I started by wiring the Shelly 2.5 to my roller shutter motor. The process involved connecting the motor’s wires to the Shelly’s terminals, which I followed carefully based on the manufacturer’s instructions. After the physical connections were secure, I proceeded to install the device on the Shelly app. This step was smooth, and I was quickly able to control the roller shutter through the app.
Testing and Calibration
Next, I moved on to calibration. This involved setting the correct directions for opening and closing the shutter. Initially, I had the directions reversed, which I quickly corrected within the app. The calibration process was quite user-friendly, and I appreciated the visual feedback that confirmed the settings were correct.
Integration with Alexa
One of my primary goals was to integrate the roller shutter with Alexa for voice control. This proved to be a breeze. I simply linked my Shelly account with Alexa, and within minutes, I was able to issue commands like, ‘Alexa, open the roller shutter.’ It was a satisfying moment seeing everything work seamlessly together.
The Unexpected Challenge
However, I soon encountered an issue that threw me off track. My existing Gira roller shutter switch, a common model with two knobs for up and down, stopped working as intended after integrating the Shelly 2.5. Instead of stopping the shutter when I released the switch, it continued moving until I pressed the switch again. This was perplexing and a bit frustrating, as I had relied on the Gira switch for manual control.
Troubleshooting and Solution
After some research and reaching out to the community, I discovered that the issue stemmed from how the Shelly 2.5 interprets the switch’s signals. The Gira switch sends a 230V signal when pressed and returns to 0V when released. The Shelly, however, was interpreting the 0V state as a command to continue the movement rather than stop it.
To resolve this, I adjusted the button type configuration in the Shelly app. After several trials, I found that setting the switch to ‘momentary’ mode solved the problem. This configuration ensures that the Shelly recognizes the 0V state as a stop command, restoring the expected functionality of the Gira switch.
Overall, integrating the Shelly 2.5 with my roller shutter was a rewarding experience. It added a new layer of convenience and automation to my home, and the ability to control everything via voice commands was a significant upgrade. The initial hiccup with the Gira switch was a valuable learning experience, and I’m grateful to the community for their insights and support.
For anyone considering a similar project, I recommend thoroughly checking the configuration settings and not hesitating to reach out to forums for advice. With a bit of patience and the right adjustments, you can achieve a seamless integration that enhances your smart home experience.
