Successful Integration of Shelly 2.5 with Selve Rollladen Motors
Hi everyone, I wanted to share my recent experience integrating a Shelly 2.5 with my Selve Rollladen motors. After some research and experimentation, I managed to get everything working smoothly! Here’s how I did it:
Setup and Configuration
I started by connecting the Shelly 2.5 to the motor’s separate switch input, as mentioned in the manual. The initial setup was straightforward—just a matter of wiring and configuring the Shelly app. However, I encountered a snag during the calibration process. The Shelly wasn’t detecting the motor’s position, which was crucial for precise control.
Problem Solving
After some digging, I realized that the Shelly needed a different wiring configuration to accurately measure the motor’s position. I adjusted the setup so that the motor wasn’t connected in parallel with the Shelly, which allowed the Shelly to detect the voltage changes needed for calibration. This tweak made all the difference!
Final Integration
Once the calibration was sorted, I set up the automation rules in Home Assistant. Now, I can control the blinds seamlessly through the Shelly app or directly via Home Assistant. It’s been a great way to enhance my home automation setup without any major hiccups.
Key Takeaways
  • Always refer to the device manual for specific wiring requirements.
  • Don’t hesitate to experiment with different configurations if the initial setup doesn’t work.
  • Home Assistant’s flexibility makes it easy to integrate and automate even complex setups.
I’m really happy with how this project turned out. It’s a great example of how a bit of troubleshooting and persistence can lead to a successful integration. If anyone has questions or needs help with similar setups, feel free to reach out!
Cheers,
