I recently managed to integrate my Tado thermostat and radiator valves into Home Assistant using the HomeKit Device integration, and I wanted to share my experience and findings. While I saw some posts mentioning the Tado integration relying on the Tado cloud, I was determined to keep everything local for better privacy and reliability.
After successfully adding the Tado Bridge and TRVs to Home Assistant, I noticed that the ‘Home/Away’ mode preset wasn’t appearing as expected. After some research and tinkering, I realized that this mode is typically handled through the Tado app but can be replicated locally with some custom automations.
Here’s what I did:
Setup: I ensured that the Tado Bridge was properly paired with my HomeKit setup within Home Assistant. This involved some initial configuration steps to make sure all devices were recognized and functional.
Custom Automations: I created custom automations within Home Assistant to mimic the ‘Home’ and ‘Away’ modes. For example, when I leave the house, an automation triggers to set the temperature to ‘Away’ mode, lowering the heat to save energy. When I return, another automation adjusts the temperature back to a comfortable level.
Integration with Other Devices: I also integrated this setup with my smart lights and security system. Now, when I’m in ‘Away’ mode, the lights dim, and the security system arms itself. When I come back, everything adjusts to ‘Home’ mode seamlessly.
Tips for Others: If you’re looking to do something similar, I recommend:
- Checking the Tado API documentation for any additional settings or commands that might be useful.
- Testing automations thoroughly to ensure they work as expected in different scenarios.
- Keeping backups of your configurations in case something goes wrong during the setup process.
This integration has made my home much more comfortable and energy-efficient. I’m excited to see how I can expand this setup further in the future!
