Hi everyone! I’m thrilled to share my experience configuring the Hass CalendarAddon for my family calendar dashboard. Initially, I faced some challenges with CSS rendering, but through persistence and troubleshooting, I managed to create a sleek and functional dashboard. Here’s how I did it:
1. Understanding the Problem:
I started by setting up the Hass CalendarAddon to pull data from multiple calendars. While some CSS styles rendered correctly, others were misaligned or displayed incorrectly. This was frustrating, especially since the dashboard looked perfect outside of Home Assistant.
2. Debugging and Adjustments:
I began by validating my raw HTML and CSS outside of HA, which worked perfectly. This indicated the issue was specific to HA. I then explored HA’s card_mod and grid capabilities, experimenting with different styles and layouts. I also ensured that external CSS resources were correctly included.
3. Key Insights:
- CSS Variables and Grid: I discovered that while CSS variables and grid layouts are supported, they require careful implementation to avoid misalignment issues.
- Browser Debugging: Using browser developer tools was invaluable. I could inspect elements, check console errors, and tweak styles in real-time.
- Community Resources: The HA community forums and GitHub repositories were fantastic resources. I found several examples and troubleshooting tips that guided me through the process.
4. Final Configuration:
After several iterations, I achieved a clean layout with proper alignment and styling. I documented my process, including the CSS setup and card configurations, to help others facing similar issues.
5. Tips for Others:
- Start with a minimal example to isolate issues.
- Leverage browser developer tools for real-time debugging.
- Don’t hesitate to reach out to the community for support.
I’m now enjoying a beautifully organized family calendar, and I hope this guide helps you achieve the same! Happy coding everyone! ![]()
