Hello everyone, I wanted to share my experience in setting up my room thermostat and radiator thermostat to work seamlessly together. I recently purchased a Devolo room thermostat and a Spirit Z-Wave radiator thermostat, and I was determined to get them integrated so that adjusting one would automatically affect the other.
Initially, I faced some challenges. The two devices were from different brands, and I wasn’t entirely sure how to get them to communicate. After some research and trial and error, I discovered that using a smart home hub that supports both Zigbee and Z-Wave protocols was the key. This allowed both devices to be part of the same ecosystem and enabled me to create rules within the hub’s app to automate their interaction.
Here’s what I did:
- Pairing the Devices: I started by pairing both devices with my hub. The Devolo room thermostat was straightforward, and the Spirit radiator thermostat was a bit trickier but still manageable through the hub’s setup wizard.
- Creating Automation Rules: Once both devices were connected, I went into the automation section of the hub’s app. I set up a rule where any change in temperature on the room thermostat would trigger a corresponding adjustment on the radiator thermostat. This involved selecting the ‘temperature change’ event from the room thermostat and specifying the desired action for the radiator thermostat.
- Testing the Setup: To ensure everything worked smoothly, I manually adjusted the temperature on the room thermostat and watched as the radiator thermostat followed suit. It was a relief to see that the integration worked perfectly without any delays or errors.
This setup has made my life much easier, especially during the colder months. Now, I don’t have to adjust each thermostat individually, saving me time and ensuring a more comfortable home environment.
If anyone else is looking to integrate their thermostats or automate their heating system, I highly recommend exploring the automation features of your smart home hub. It’s a fantastic way to streamline your home’s heating system and enhance your overall smart home experience. Happy tinkering! ![]()
