After spending quite some time figuring out how to integrate my Schneider PowerTags with Modbus and the Acti9 Smartlink SI D, I wanted to share my journey and solution with the community. This guide is perfect for anyone looking to monitor their electrical consumption with precision and automation.
My Setup
I have a setup consisting of:
- 1x Acti9 Smartlink SI D (A9XMWA20)
- 2x Acti9 PowerTag 1p+N (A9MEM1521)
The Smartlink was a breeze to set up, but the real challenge was configuring the Modbus settings to read all the necessary data points from my PowerTags. Here’s how I did it.
Configuration Steps
- Identify the Phase Connections: When setting up the Smartlink, make sure to note the phase connections as this is crucial for accurate readings.
- Auto-Addressing: The Smartlink automatically assigns addresses starting from 150. My PowerTags were assigned to 150 and 151.
- Modbus Configuration in
configuration.yaml: Below is the YAML configuration I used to pull data from both PowerTags. This includes power, power factor, energy consumption, temperature, and voltage/current readings.
yaml
modbus:
- name: “hub2”
type: tcp
host: 192.168.x.x
port: 502
sensors:- name: “Powertag: Name 1”
device_class: power
state_class: measurement
slave: 151
address: 3059
unit_of_measurement: W
count: 2
precision: 1
scan_interval: 2
data_type: float
Additional sensor configurations for voltage, current, etc.
Key Learnings
- Temperature Readings: I noticed that temperature readings weren’t showing up initially. It turned out my PowerTag model doesn’t have a temperature sensor. Always check your device specs!
- Multiple Modbus Adapters: If you have several devices, organizing them into separate hubs (
hub1,hub2) can streamline your setup.
Community Contributions
I hope this guide helps others avoid the trial and error I went through. If anyone has tips or improvements, I’d love to hear them! Let’s keep the community knowledge flowing.
Happy automating! ![]()
