Hey everyone, I wanted to share my experience with setting up the Wyze Cam V3. I recently purchased two of these cameras, and while one connected seamlessly, the other gave me quite a bit of trouble. Here’s how I resolved the issue and got both cameras up and running smoothly.
Initially, I faced a problem where one camera would constantly show as offline with error 90, while the other worked perfectly. After some research and troubleshooting, I discovered that the issue might be related to interference between the two cameras. Here’s what I did:
Reset Both Cameras: I started by resetting both cameras to their factory settings. This involved holding down the power button for about 10 seconds until the LED light started flashing.
Check Wi-Fi Settings: I made sure my router was configured optimally. I switched from WPA3 to WPA2-PSK and ensured that both 2.4GHz and 5GHz bands were enabled. I also placed the cameras in different locations to minimize interference.
Firmware Update: I checked for any available firmware updates for both the cameras and the Wyze app. Updating the firmware resolved some connectivity issues and improved overall performance.
Reconfiguration: I uninstalled and reinstalled the Wyze app, then went through the setup process again for both cameras. This time, I made sure to follow each step carefully and avoid any rushed actions.
After following these steps, both cameras are now working perfectly without any interference. It was a bit frustrating at first, but methodical troubleshooting paid off!
For anyone else dealing with similar issues, here are some tips:
- Always reset cameras to factory settings if you’re experiencing persistent problems.
- Optimize your router settings and ensure there’s no interference from other devices.
- Keep your firmware updated, as these updates often include bug fixes and performance improvements.
I’m now enjoying seamless video surveillance with both cameras, and I’m much more confident in setting up additional devices in the future. Happy smart home hacking everyone! ![]()
