Hey everyone, I wanted to share my recent experience setting up Zigbee devices in Home Assistant. I’ve been using Zigbee devices for a while now, but recently I faced a bit of a challenge when several of my devices stopped working. After some troubleshooting, I realized it was due to interference from another device in my setup. I had a Raspberry Pi sitting near my Zigbee hub, and it turns out they were too close, causing some wireless interference.
After moving the Raspberry Pi to another room, everything worked perfectly again. It was a simple fix, but it taught me the importance of placement when dealing with wireless devices. I also dusted off my hub and made sure there were no obstructions blocking the signals.
If you’re experiencing similar issues, I recommend checking the placement of your hub and ensuring there are no other devices causing interference. Also, make sure your hub is on a stable channel and that your Zigbee devices are properly paired.
I hope this helps someone out there who might be struggling with their Zigbee setup. It’s always a relief to get everything working smoothly again! ![]()
