Successfully Connecting Pro4 Cameras to SmartHub via Wi-Fi
Hi everyone, I wanted to share my recent experience with connecting my Pro4 cameras to the SmartHub VMB4540 using Wi-Fi. While it was initially a bit challenging, I managed to find a solution that works perfectly for my setup. The Problem: After moving my network equipment, my Pro4 cameras lost connection to the SmartHub. The cameras are equipped with Wi-Fi, and the hub is connected via Ethernet, so I knew Wi-Fi should be a viable solution. However, the cameras weren’t automatically connecting to the hub over the network. The Solution: After some research and trial and error, I discovered that manually configuring the Wi-Fi settings on each camera was the key. Here’s what I did: 1. Reset the Cameras: I reset each Pro4 camera to factory settings to ensure a clean connection. 2. Reconfigure Wi-Fi: I used the Arlo app to manually enter the network SSID and password for each camera. 3. Check Network Settings: I ensured that the SmartHub was on the same network and that there were no firewalls blocking communication. 4. Test Connections: After configuring, I tested each camera to confirm it was communicating with the hub. Key Takeaways: - Always reset devices to factory settings when troubleshooting connections. - Manual configuration can sometimes be more reliable than automatic detection. - Ensure all devices are on the same network and check firewall settings. I hope this helps anyone else facing similar issues! It was a bit of a hassle, but getting everything working smoothly was worth it. :blush:
