I wanted to share my recent success in creating a custom template device for my IQAir air purifier. After spending quite some time researching and experimenting, I managed to replicate all the functionalities of a smart air purifier using a combination of sensors and automation. Here’s a quick rundown of my journey and what I learned along the way.
The Challenge:
My IQAir unit is a beast when it comes to air quality, but it’s not exactly ‘smart.’ I wanted to integrate it seamlessly into my smart home ecosystem without having to replace it with a newer model. The goal was to have full control over its settings, monitor its performance, and even track filter life – all from my smartphone or voice assistant.
The Solution:
I decided to create a custom template device in Home Assistant. This involved setting up several sensors to monitor different aspects of the air purifier:
- Particle Count (PM): I used a small smart sensor to track air quality in real-time.
- Temperature and Humidity: Another sensor was added to monitor environmental conditions.
- Fan Speed Control: I integrated a Zigbee-based IR remote to control the fan speed without needing to physically interact with the unit.
- On/Off Control: Similarly, I used another Zigbee IR remote to handle the power toggling.
- Filter Life Tracking: This was a bit tricky, but I managed to create a system that estimates filter life based on usage patterns and fan speed.
The Outcome:
After a few weeks of tweaking and testing, the setup is now fully functional! I can now:
- Turn the air purifier on/off remotely.
- Adjust fan speeds via my voice assistant or through the Home Assistant app.
- Monitor air quality, temperature, and humidity in real-time.
- Get notifications when it’s time to change the filters.
Lessons Learned:
- Start Small: Begin with one functionality at a time and test each component thoroughly before integrating them.
- Documentation is Key: Keep detailed notes of your setup, including sensor placements and automation rules. This will save you a lot of time if you need to troubleshoot later.
- Community Support: Don’t hesitate to reach out to forums and communities. The smart home community is incredibly supportive, and you’ll likely find someone who’s tackled a similar project.
- Patience is a Virtue: Custom setups can be time-consuming, but the satisfaction of seeing everything come together is well worth the effort.
If anyone is considering a similar project, I’d be happy to share more detailed steps or answer any questions you might have. Happy tinkering! ![]()
