Successfully Installing Coral USB Accelerator on Raspberry Pi
Hello everyone! I wanted to share my recent experience with installing the Coral USB Accelerator on my Raspberry Pi. It was a bit of a challenge, but I managed to get it working, and I thought I’d document the process in case anyone else is trying to do the same.
First, a little background: I’ve been using Home Assistant on a Raspberry Pi 4 for a while now, and I recently decided to upgrade my setup to include Frigate for motion detection. However, I quickly realized that relying solely on the Pi’s CPU wasn’t going to cut it—it was causing some lag and wasn’t as efficient as I hoped it would be. That’s when I came across the Coral USB Accelerator. It seemed like the perfect solution to offload some of the processing power needed for Frigate.
The installation process wasn’t straightforward, especially since I’m still pretty new to this. I started by trying to install the Coral USB while running Home Assistant OS directly on the Pi. Unfortunately, I ran into issues where the system didn’t recognize the accelerator. After some research, I found a thread suggesting that I might need to install it using Raspberry Pi OS instead of Home Assistant OS. That was a bit daunting, but I decided to give it a shot.
Here’s what I did:
  1. Backing Up and Preparing: I made sure to back up all my important data on the Pi. Then, I powered it down and removed the SSD I was using for Home Assistant. I created a bootable USB thumb drive with Raspberry Pi OS using Raspberry Imager.
  2. Installing Raspberry Pi OS: I booted the Pi from the USB thumb drive and set it up. This was a fresh install, so I took the time to configure it properly and make sure everything was up to date.
  3. Setting Up the Coral USB Accelerator: Once the system was up and running, I followed the instructions to install the Edge TPU runtime and the PyCoral library. This involved running a few commands in the terminal, which I found a bit intimidating, but I managed to get through them step by step.
  4. Testing the Setup: After installing the necessary software, I tested the Coral USB Accelerator by running a sample model. It worked perfectly! The accelerator was recognized, and the model ran smoothly. This was a huge relief after the initial struggles.
  5. Reverting to Home Assistant OS: Once I was confident that the Coral USB was working correctly, I powered down the Pi again, removed the USB thumb drive, and reattached my Home Assistant SSD. I was worried that the installation might interfere with my existing setup, but everything worked as expected. Frigate now runs much more efficiently, and I can see a noticeable improvement in performance.
Reflecting on the process, I realize how important it was to take it one step at a time. I was initially hesitant to switch from Home Assistant OS, but it turned out to be the right move. If I were to offer any advice to others looking to do the same, it would be to thoroughly research the installation process, back up your data, and don’t be afraid to reach out to the community for help if you run into issues.
Overall, this experience taught me a lot about troubleshooting and the importance of a good backup strategy. It also reinforced my belief in the power of open-source communities and how much you can achieve with the right resources and a bit of persistence. I’m really happy with how everything turned out, and I’m excited to see how this upgrade will enhance my smart home setup in the long run. Thanks to everyone who contributed to the resources that helped me along the way!
