Successfully Installing Ring Pro Doorbell Directly to a Transformer
After some research and a bit of trial and error, I successfully installed my Ring Pro doorbell directly to a transformer in the attic. Here’s a quick rundown of my experience in case anyone else is tackling a similar project!
First, I reviewed the installation guide provided by Ring, but I found it a bit confusing when it came to using the transformer without an existing doorbell system. The key was understanding the difference between the ‘Advanced Power Kit’ and the ‘Pro Power Kit.’ Turns out, the wires I received with my Ring Pro were indeed part of the ‘Pro Power Kit,’ which simplifies things a bit.
I started by turning off the power to the circuit to ensure safety. Then, I located the transformer in the attic and carefully connected the wires from the Ring Pro kit to the transformer terminals. It was a bit tricky figuring out the correct polarity, but using a multimeter helped confirm that everything was connected properly.
Once the wiring was done, I reconnected the power and tested the doorbell. It powered on immediately, and the chime sounded perfectly. I was relieved to see that the installation went smoothly without any hiccups!
A few tips for anyone attempting this:
  • Double-check the transformer’s voltage to ensure it’s within the recommended range (16-24 VAC).
  • Use wire connectors that are compatible with your transformer to avoid any potential issues.
  • If you’re unsure about any step, don’t hesitate to reach out to Ring support or consult additional resources online.
Overall, it was a satisfying project, and I’m happy to have my Ring Pro up and running without the need for an additional doorbell system. It’s a great addition to my home security setup!
