Successfully Integrated Bird's Eye View in OpenHAB
Hey everyone, I wanted to share my recent success in integrating the Bird’s Eye View from Frigate into my OpenHAB setup. I’ve been working on this for a while, and it’s finally coming together! Here’s my journey and some tips for anyone looking to do the same.
First, I set up Frigate on my Raspberry Pi, ensuring that the Bird’s Eye View was enabled in the configuration. Once that was done, I moved on to OpenHAB. I installed the necessary MQTT binding and configured the server details. It was a bit tricky getting the ffmpeg path right, but I managed it by checking the OpenHAB logs for any ffmpeg-related errors.
After setting up the server, I created a widget in my OpenHAB UI using the oh-video-card component. The key was ensuring the URL was correctly pointing to the Bird’s Eye stream. I tested it with the direct URL from Frigate in my browser to confirm it was working before integrating it into OpenHAB.
Initially, I faced some issues where the video wouldn’t load, and I kept getting the ‘media could not be loaded’ error. I spent hours checking my configurations, but everything seemed correct. Then, I realized that the ffmpeg version on my OpenHAB VM might be the culprit. I updated ffmpeg and made sure the path was correctly specified in the Frigate Server Thing configuration. That did the trick!
Now, I have a seamless Bird’s Eye View integration that allows me to monitor all my cameras with minimal CPU and network load. It’s amazing how much this setup has improved my home surveillance system. I can now keep an eye on everything from my living room to the backyard without any lag or buffering.
For anyone looking to do this, here are a few tips:
  • Ensure ffmpeg is installed and correctly configured on your OpenHAB VM.
  • Double-check the MQTT binding settings and server URLs.
  • Test the stream URL outside of OpenHAB before integrating it.
  • Don’t hesitate to look through the logs for any ffmpeg-related errors—they can be really helpful!
I’m really happy with how this turned out and can’t recommend this setup enough for anyone looking to enhance their home surveillance. If you have any questions or run into any issues, feel free to reach out—I’m happy to help!
Cheers,
