Hi everyone, I wanted to share my recent success in integrating my Bluetti Power System into my smart home setup using MQTT and HomeAssistant. This project has been a great learning experience and has added a significant layer of convenience to my energy monitoring.I started by installing Mosquitto on my primary HomeAssistant server, which served as the MQTT broker. The next step was setting up the Bluetti MQTT component on a Raspberry Pi that would handle the Bluetooth communication with my Bluetti AC300. I found that using an external Bluetooth dongle greatly improved the connection stability, especially since the built-in Bluetooth on the Raspberry Pi was quite low power.Configuring the MQTT binding in HomeAssistant was straightforward, but I encountered some initial issues with data consistency. After some research, I discovered that installing the Jinja Transformation add-on was crucial for proper data rendering and control functionality. This addition made a world of difference, ensuring that the data from my Bluetti system was both accurate and reliable.One of the most rewarding aspects of this project has been the ability to monitor my solar energy production in real-time. The sharp cutoff in my power graph when the battery reached full capacity was a fascinating insight into how efficiently my system operates. This setup not only provides peace of mind but also helps in optimizing energy usage.I would like to extend a huge thank you to the developer of the Bluetti MQTT component and the HomeAssistant community for their invaluable resources and support. This integration has been a fantastic addition to my smart home ecosystem, and I hope this post inspires others to explore similar projects.If anyone has questions or needs assistance with their own Bluetti integration, feel free to reach out! Happy tinkering! ![]()
