Successfully Integrating Fire TV Stick with Home Assistant: A Step-by-Step Guide
Hello fellow Home Assistant enthusiasts! :video_game: I wanted to share my recent success in integrating my Fire TV Stick with Home Assistant. After some research and a bit of trial and error, I managed to get everything working smoothly. I thought it would be helpful to document my process for anyone else looking to do the same.
My Setup
Before diving in, let me share my system setup:
  • Home Assistant: Running on Ubuntu 18.04 with Hass.io
  • Device: Amazon Fire TV Stick 4K
Integration Steps
  1. Enable ADB Debugging on Fire TV Stick
    • Navigate to Settings > System > Developer Options on your Fire TV Stick.
    • Enable ADB debugging.
  2. Install the ADB Addon in Hass.io
    • Go to your Hass.io dashboard and navigate to Add-ons.
    • Search for and install the ADB - Android Debug Bridge addon.
    • Configure the addon with your Fire TV Stick’s IP address and desired reconnect timeout.
  3. Configure Home Assistant
    • Open your configuration.yaml file.
    • Add the following configuration under the media_player section:
yaml
media_player:
  • platform: androidtv
    device_class: firetv
    host: 192.168.x.xyz
    adbkey: “/share/android/adbkeys/adbkey”
    adb_server_ip: 192.168.x.abc
    adb_server_port: 5037
    get_sources: false
  1. Restart and Verify
    • Restart both the ADB addon and Home Assistant.
    • Check your logs to ensure the connection is successful. You should see messages indicating that the Fire TV Stick is connected.
Challenges and Solutions
Initially, I faced an issue where the Fire TV entry wasn’t showing up in Home Assistant, even after restarting the system. After some troubleshooting, I realized that the adbkey path needed to be correctly specified, and the firewall settings on my router were blocking the connection. Once I adjusted these, everything fell into place!
Tips for a Seamless Integration
  • Ensure Stable Network Connection: Make sure your Fire TV Stick and Home Assistant are on the same network with a stable connection.
  • Regularly Update Addons: Keep your Hass.io addons updated to benefit from the latest features and bug fixes.
  • Backup Configuration: Always keep a backup of your configuration.yaml file before making changes.
Conclusion
Integrating my Fire TV Stick with Home Assistant has been a fantastic experience. It now seamlessly integrates with my smart home setup, allowing me to control my Fire TV Stick through voice commands or the Home Assistant interface. I’m excited to explore more automation possibilities with this integration!
A huge thank you to the Home Assistant community for the wealth of resources and support available! If anyone has questions or needs help with their setup, feel free to reach out. Happy automating! :rocket:
