Successfully Integrating Govee Floor Lamp 2 with HomeKit via Matter
Hey everyone! I wanted to share my recent success in integrating the Govee Floor Lamp 2 with HomeKit using Matter. It was a bit of a journey, but I managed to get it working smoothly. Here’s what I learned along the way:
  1. Check Your IPv6 Settings: I initially struggled because my ISP had turned off IPv6. Ensuring that both my router and ISP had IPv6 enabled was crucial for Matter to work properly.
  2. Dedicated WiFi Network: Setting up a separate 2.4GHz WiFi network for IoT devices helped eliminate interference. I used a legacy mode with 20MHz bandwidth and 802.11n standards, which made a big difference in reliability.
  3. Apple TV as a Bridge: Connecting my Apple TV via Ethernet proved to be a stable solution. It acted as a reliable bridge between my iPhone and the Govee lamp during the setup process.
  4. Factory Reset: I couldn’t stress enough how important it was to perform a proper factory reset on the lamp. Turning it off at the wall for 30 seconds and following the reset procedure ensured a clean setup.
  5. Setup via Home App: Instead of using the Govee app first, I used the Home app and scanned the Matter QR code provided with the lamp. This direct approach worked seamlessly.
  6. Post-Setup Configuration: After setting up in HomeKit, I connected the lamp to the Govee app for additional customization. It’s worth noting that remote access via the Govee app isn’t possible outside the local network, but HomeKit handles everything perfectly.
  7. Power Outage Recovery: I observed that the lamp takes about 5-10 minutes to reconnect after a power outage. It temporarily shows as ‘Not Responding,’ but it comes back online without any issues.
This setup has transformed my living space, and I’m thrilled with how everything works together. If anyone is struggling with similar issues, I hope these tips help you get your Govee devices up and running smoothly! :bulb::sparkles:
Btw. Have anyone tried add Govee Uplighter Floor Lamp to Aqara app, and the sync it to Apple home?
