Successfully Integrating Homematic IP Thermostat with Google Assistant in OH3
I recently embarked on a project to integrate my Homematic IP Thermostat (HmIP-eTRV-2) with Google Assistant through OpenHAB3, and I wanted to share my journey and solution in case it helps others facing similar challenges.
The Goal: Control my thermostat via voice commands using Google Assistant. Sounds straightforward, but the setup wasn’t as smooth as I hoped. Let me walk through what I did.
The Setup Process:
  1. Initial Configuration: I started by setting up the thermostat in OpenHAB3 using the Homematic IP binding. Everything seemed to work fine in the OpenHAB interface.
  2. Google Assistant Integration: Next, I followed the official OpenHAB documentation to expose the thermostat to Google Assistant. This involved creating an Item Group and setting up the necessary metadata. However, despite following the steps, the thermostat wasn’t showing up correctly in Google Home.
The Challenge: After several attempts, the thermostat appeared in Google Home but without any functionality. It was frustrating because I knew the hardware and OpenHAB setup were correct. I started questioning whether I needed the Item Group or if the Semantic Model was sufficient.
The Solution: After some research and trial and error, I realized that while the Item Group method is mentioned, the Semantic Model approach is more reliable for Google Assistant integration. Here’s what worked for me:
  • Defining Equipment: Instead of creating an Item Group, I defined the thermostat as Equipment in the Google Assistant settings. This involved associating the relevant items (like temperature control and setpoint) with the thermostat.
  • Metadata Tags: Ensuring that the metadata tags were correctly applied was crucial. I made sure to set the correct device type and attributes so Google Assistant could recognize it properly.
The Outcome: After correcting the setup, the thermostat now works seamlessly with Google Assistant. I can adjust the temperature and check the current settings using voice commands, which is incredibly convenient.
Tips for Others:
  • Double-check your metadata tags and ensure they match Google Assistant’s expectations.
  • If the Item Group method isn’t working, try the Semantic Model approach—it might be more straightforward.
  • Don’t hesitate to consult the community forums or documentation if you’re stuck. There’s a wealth of information and helpful users out there.
I’m thrilled to have this integration working smoothly now. It’s a great example of how OpenHAB can bridge different smart home ecosystems, making life a bit easier and more comfortable.
