Successfully Integrating Homematic System Variables into OpenHAB
Hey everyone, I wanted to share my recent success in integrating Homematic system variables into OpenHAB. I’ve been working on this for a while and thought I’d document my journey in case it helps anyone else out there!
So, the goal was to pull the state of my alarm system into OpenHAB using a Homematic system variable. I created the variable in Homematic (running on an Intel NUC with Debmatic), but when I looked into OpenHAB, it wasn’t showing up. I checked under Gateway Extras, where I saw a default system variable called “Anwesenheit,” but mine wasn’t listed. Frustrating, right?
After some research and trial and error, I figured out that the issue was with how the system variables are exposed in Homematic. It turns out that not all system variables are automatically visible in OpenHAB unless they’re specifically configured. I had to tweak the Homematic gateway settings to ensure that custom system variables are recognized.
Here’s what I did:
  1. I made sure the Homematic binding was up to date.
  2. I checked the gateway configuration to ensure it was set to expose all system variables.
  3. I restarted the gateway and OpenHAB to apply the changes.
  4. After a few minutes, my custom system variable appeared in OpenHAB!
It’s such a relief when everything finally clicks into place. I’m now using this system variable to trigger automations based on my alarm system’s state. For example, when the alarm is triggered, it automatically turns on my security lights and sends a notification to my phone.
A few tips for anyone tackling this:
  • Always check the OpenHAB logs for any clues. They can be a goldmine of information.
  • Make sure your Homematic gateway is correctly configured to expose custom variables.
  • Don’t hesitate to reach out to the community if you’re stuck. There are some amazing experts out there willing to help!
I hope this helps someone else avoid the frustration I went through. Happy automating! :rocket:
