Hi everyone! I’ve been diving into smart lighting automation with my Hue Group setup, and I wanted to share my journey and solution for anyone facing similar challenges.
I recently encountered an issue where I couldn’t retrieve the current state level and switch status for my Hue Group. The error message indicated that the ‘currentState’ and ‘currentValue’ commands weren’t supported. At first, I was a bit puzzled, but after some research and experimentation, I figured out a reliable method to achieve the desired functionality.
Here’s what I discovered: Instead of using the ‘currentState’ or ‘currentValue’ commands, I needed to utilize the ‘status’ command. This approach provides the necessary information about the group’s current state, including the brightness level and whether the lights are on or off.
To implement this, I updated my script to use the ‘status’ command and integrated it into my automation rules. This change not only resolved the issue but also enhanced the reliability of my smart lighting setup.
For anyone looking to automate their Hue Group, here’s a quick tip: Always check the supported commands for your devices and explore alternative methods if the initial approach doesn’t work. The Hue ecosystem is incredibly versatile, and with a bit of creativity, you can achieve almost any automation goal.
I hope this helps someone out there! Happy automating! ![]()
