I’ve always been fascinated by the potential of integrating different smart home devices and software platforms. Recently, I decided to explore using iSpy Server to capture images from my USB camera and display them on Vera. While the idea seemed straightforward, I encountered a few challenges along the way.
Initially, I set up iSpy Server on my PC and configured it to capture images from the USB camera inside my house. Vera was able to display the image on the server’s web page, but the connection wasn’t reliable. To make things more frustrating, none of the Android apps I use—Vera Mobile, Authomation, or Home Buddy—could display this camera. I know a few folks who are using iSpy, so I thought maybe they could shed some light on the issue.
I reached out to the community and asked if anyone could share their device settings or if they were running a different program like Yawcam. Unfortunately, I couldn’t get Vera to pick up anything from Yawcam either. After some research and trial and error, I discovered that the issue might be related to how Vera handles external image sources. It seems that Vera requires a specific setup to reliably display images from an external server.
Here’s what I learned: First, ensure that iSpy Server is running on a stable network connection. Second, configure Vera to point to the correct image URL provided by iSpy. I also found that using the built-in web server in Vera helped stabilize the connection. Finally, I adjusted the refresh rate settings in Vera to ensure the image updates reliably.
While the process was a bit of a learning curve, it was rewarding to see everything working smoothly in the end. I’d like to thank everyone in the community who took the time to offer suggestions and support. It’s amazing how a collaborative community can help solve even the trickiest of problems!
If anyone else is looking to integrate iSpy with Vera or has tips on optimizing this setup, I’d love to hear from you. Let’s keep the knowledge sharing going! ![]()
