Successfully Integrating Multiple Brands for Electric Heating Automation
Hi everyone, I wanted to share my recent experience setting up a home automation system to manage my electric heating system. I live in Switzerland, and each room has a radiator connected to an electrical outlet. My goal was to automate the heating system using smart devices, and I thought I’d document my journey in case it helps anyone else.
I started by researching the hardware I needed. I decided to go with a Raspberry Pi 4 running HomeAssistant, as it seemed like a solid choice for a home automation hub. For temperature monitoring, I chose the Xiaomi Mijia Bluetooth thermometer, which I’ve heard great things about. To control the radiators, I opted for Ikea TRÅDFRI wireless smart outlets. I was a bit unsure if I needed a gateway, but after some research, I realized the Raspberry Pi could handle everything with the right software setup.
Setting up the system was a bit of a learning curve, but I managed to get everything connected. I used the Xiaomi app to pair the thermometers and the Ikea app to control the outlets. Then, I integrated everything into HomeAssistant. It was amazing to see everything work together seamlessly. Now, each radiator turns on automatically when the temperature drops below the set threshold, and I can monitor and adjust everything from my phone.
One thing I was worried about was compatibility. I’ve heard stories of devices not working together, especially from different brands. But so far, everything has worked perfectly. The only hiccup I had was with my Vera unit, which would restart at 2:30 am every morning. I’m still not sure why it does that, but I found a workaround by disabling the automatic restart in the settings. I’m hoping to figure out the root cause soon.
I also wanted to mention the support I received from this community. When I was stuck with the Vera restart issue, someone suggested checking the logs and looking for any patterns. That small tip helped me stabilize my system, and I’m really grateful for that.
If anyone else is looking to set up a similar system, here are a few tips I learned along the way:
  • Research hardware compatibility before making any purchases.
  • Start small and gradually add more devices as you get comfortable.
  • Don’t hesitate to ask for help. The community here is fantastic and always willing to assist.
Overall, I’m thrilled with how everything turned out. It’s been a great way to make my home more comfortable and energy-efficient. I can’t wait to see what other automations I can add in the future!
