I’ve been on a bit of a rollercoaster trying to get OpenHAB 2.5.3 working with MariaDB for persistence. Let me share my journey and hopefully help others avoid some pitfalls!
The Challenge
I wanted to use MariaDB as my persistence layer, but kept running into errors with the ‘openhab-persistence-jdbc’ feature. Logs showed connection issues and driver class not found errors. I tried everything from reinstalling the feature to manually placing the JDBC driver in the addons folder, but nothing stuck.
The Solution
After hours of troubleshooting, I realized the issue was with the JDBC driver compatibility. Here’s what worked for me:
Install the Latest JDBC Driver
- Download the latest MariaDB JDBC driver (version 2.7.3 or higher) from the official MariaDB website.
- Place the JAR file in the
openhab/addonsdirectory.
Configure persistence.xml
- Add the following configuration to your
persistence.xml:
xml
jdbc
org.openhab.persistence.jdbc.internal.JdbcPersistenceServiceFactory
jdbc:mariadb://localhost:3306/openhab
openhab
your_password
org.mariadb.jdbc.Driver
Restart OpenHAB
- After making these changes, restart OpenHAB to apply the new configuration.
The Outcome
It was a relief when everything finally connected! My data is now persisting correctly in MariaDB, and I can query historical data without any issues. This setup has made my smart home system more robust and reliable.
Tips for Others
- Always ensure your JDBC driver is compatible with your MariaDB version.
- Double-check your database credentials and connection URL.
- If you’re still having issues, try clearing the OpenHAB data directory and letting it recreate the necessary tables.
If anyone has additional tips or encountered similar issues, I’d love to hear about your experiences!
