Hey everyone! I wanted to share my recent success in integrating OpenWeatherMap with Home Assistant to automate my heating system. I have both a Heat Pump and an Oil Fired Boiler, and I wanted to optimize their efficiency based on outdoor temperatures. Here’s how I did it:
Setup: I registered for OpenWeatherMap (free tier worked perfectly for me) and created a sensor for the outdoor temperature. The accuracy has been impressive, especially in my location in the Northeast US.
Integration: I followed the Home Assistant documentation to set up the OpenWeatherMap integration. Here’s the configuration I used:
yaml
sensor:
- platform: openweathermap
api_key: MY_API_KEY
monitored_conditions:- temperature
- Automation: I created two automations:
- One switches off the Heat Pump and turns on the Oil Fired Boiler if the temperature drops below 35°F for 30 minutes.
- Another switches back to the Heat Pump when the temperature rises above 36°F for 30 minutes.
- Results: This setup has been running smoothly for me, ensuring optimal heating efficiency without manual intervention. It’s been a great way to save energy and reduce costs!
I hope this helps someone looking to integrate weather data into their smart home setup. If you have any questions or suggestions, feel free to reach out! ![]()
